66 390hp starter - NCRS Discussion Boards
66 390hp starter
  • Jeremy Hedges
    66 390hp starter
    When you turn the key to the start position, which terminal should get juice, the S or the R on the solenoid? I have power with the key turned to the on position, and juice at the large terminal, but the car will not crank.
    Jeremy Hedges
    #31711
    • 43240
    Re: 66 390hp starter
    Jeremy-----
    The "S" terminal of the starter solenoid is the energizing terminal. The purple wire, and only the purple wire, should be connected to it.
    • Wayne W.
      • April 30, 1982
      • 3605
      Purple wire on the inside starter terminal.
