I am getting a '66 390hp with A/C back together and have a few wiring questions. First of all the horn relay wiring only has one "Fork" wire going to it, it is the red wire that goes under the screw on the left. There are two others that plug into the bottom, but this is not another wire to go under the right hand screw. Is this corrrect? Second, the harness that goes thru the firewall to the A/C outer box, the one that connects tot he relays and fan, there is a red wire and a black wire, both with round connectors, like a bolt would go thru. They look as though they go to the starter. Red on solinoid, black on starter mount bolt to block? And on the engine forward harness of course there are there are the same two wires, connectors and colors are the same. I have found that with an A/C car, some of the connectors on a non A/C car are just taped back. Do I connect both red and both black wires to the starter and starter ground? Or do I not use the black and red wires from the forward engine harness? Please advise. Scematic is not clear to me on this.
Jeremy Hedges
#31711
Jeremy Hedges
#31711
