Just a Corvette - NCRS Discussion Boards
Just a Corvette
  • Roy B.
    • February 1, 1975
    • 7044
    Just a Corvette
    Years before the word "Trailer Queen" was used I pulled a trailer!
    • 3416
    Re: Just a Corvette
    Roy,
    Quite sporty shoes (black and white?) to drive a sporty car.
    • Jim K.
      • August 31, 2000
      • 554
      Re: Just a Corvette
      Hi Roy:
      I have been trying to get a trailer hitch for my 61 for over a year now with no luck at all. I'm hoping for something that I don't have to weld on. Just to tow a small motorcycle type trailer to help get all my stuff to Carlisle. What can you tell me?
      Thanks!!!
      Jim
      P.s. put almost 10,000 miles on her this year...
      • Jim T.
        • March 1, 1993
        • 5351
        Re: Just a Corvette
        I have never owned a pickup. Back in the 80's I would hook up my motorcycle trailor to my 70 Corvette and go to the woods and cut a load of firewood. I would cut trees into multiple foot lenghts and load the trailor. Had a plastic storage container for the chain saw that I would strap to the 70's luggage rack. Did this for several seasons until I lost my cutting privledges. Wish I had taken pictures of my 70 in the wilderness with a load of firewood. The 70's 350/300 turbo 400 never strained to pull a load out of the woods.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: Just a Corvette
          Jim! OK it's simple I used a three side square steel section about 18in. Long that slipped over the rear cross bar as seen and using two bolts is all it takes. Welded on was a slide in tow bar as seen also to clear my body. Then if you wont later just brass the holes closed and paint . I also because of the trailer I added air shocks to aid the rear springs. And added power brakes that I wrote about to also help stop the trailer. It's simple to remove when not needed and don't screw up the Corvette. I ran the trailer wire out the spare tire drain hole also.
          My 55 don't even know the trailer is behind it.
          Dont tell NCRS I told you so some people think I destroyed the Corvette.
          • Stephen B.
            • April 1, 1988
            • 876
            Re: Just a Corvette
            Ilove seeing old Corvette actually used!!!
            • Jacob A.
              • December 1, 2003
              • 237
              Re: Just a Corvette
              That picture is awesome!
              My Sunfire Yellow 67 has a dealer installed G.M. Hitch and Ball. They screwed it in with bolts right into the chrome bumpers.
              The original owner, whom I purchased the car from in July, told me he used to park with all his buddies off the highway onto a sandy area by the beach in Pensacola. He was the only one with posi-trac... and he used the ball to pull his friends out of the sand, over and over for the first few years of the car's life!
              Happy Holidays!
              • Terry R.
                • March 1, 2005
                • 359
                Re: Just a Corvette
                Hi Jim when I bought my '62 in N.C. it came with a small enclosed trailer that I pulled to Southern Ca. I'll get you some pictures.
                • Terry D.
                  • May 31, 1987
                  • 2696
                  Re: Just a Corvette
                  Jim
                  A trailer hitch for a 62 was a dealer option. I have one but it might take me a while to find it. It bolted on, one bolt to the frame crossmember and two bolts to the license plate bracket. When I get it out I will take a picture and send it. You can find them at swap meets and e-bay once in awhile.
                  • Jim K.
                    • August 31, 2000
                    • 554
                    Re: Just a Corvette
                    Yes!!! Terry and Roy, thank you! I would love more pictures and you can send them to me if it is a problem doing it here. jkennedy@gilbaneco.com
                    Jim
                    • Terry R.
                      • March 1, 2005
                      • 359
                      Re: Just a Corvette
                      The hitch is bolted on with four 1/2 inch bolts to rear crossmember.
                      • Terry R.
                        • March 1, 2005
                        • 359
                        Re: Just a Corvette *NM*
                        • Terry R.
                          • March 1, 2005
                          • 359
                          • Terry R.
                            • March 1, 2005
                            • 359
                            Re: Just a Corvette
                            Sorry for the multiple posts,I am multiple picture challenged!
