Brake Assist Instalation - NCRS Discussion Boards
  • Don #44697
    I have a 68 Corvette with the Big Block 427. I am changing the brakes by adding a brake assist unit. I used the bottom two holes in the fire wall and had to drill two additional holes to make the bolts fit.
    The unit is to low and the Master cylinder is against the wheel well.
    How do I install the unit to move it toward the engine to make room for the cylinder ?
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: Brake Assist Instalation
    Sounds like you have the incorrect power brake booster assy.....
    Might want to double check with a '68 owner for photos or check your AIM for some help....
