C! Wiper Motor - NCRS Discussion Boards
C! Wiper Motor
  • Lee D.
    • September 30, 2000
    • 12
    C! Wiper Motor
    C1 wiper motor voltage
    Recently replaced my distributor to an HEI with a 383 stroker motor in my '59.
    Removed the white resistor from my dash and want to run the wiper motor front a 12 volt line from the dash, probably off the ammeter or someplace.
    I am hesistant to do this as the resistor was in line to the wiper motor.
    Did this resistor act like a fuse or did it limit the voltage going into the wiper motor.
    The wiper motor works and I do not wish to burn it out.
    Thanks for your help
    Lee
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Lee, The resistor was only used to lower....
    ...the voltage to the coil. The wiper motor uses 12 volts and is hooked to the 12 volt side of the resistor. So, you simply could solder the original 12 volt wire that went to the resistor to the wiper motor.
