Just found another great assembly line shot that I've cropped/enlarged to show the steering gear coupler. Clearly shows the flange without rubber attached to the steering gear and the portion of the coupler with the rubber cushion attached to the upper steering column shaft. Coupler assembly bolt threaded ends and nuts facing forward. Hope someone is saving these pic's.
C2: Steering Gear Coupler
