I am helping my friend work out the bugs on his frame off 66. He says he has no headlights or parking lights. New harnesses installed
After I eliminate the obvious like firewall connections my suspicion is either the dimmer switch or the headlight switch.
Since the parking lamps do not appear to get any power from the dimmer switch would the headlight switch be the likely suspect?
The headlights raise and lower which tells me the circuit breaker is closed
Any known issues with Lectric Limited harness?
Randy
Randy
