C2 wheel porosity...... - NCRS Discussion Boards
  • Bill W.
    • November 1, 1977
    • 402
    I am restoring a set of early 1964 K-H aluminum wheels. These wheels are original (as per window sticker) to a 365 horse car built in October of '63. During the restoration process I noticed all five valve stem holes have been enlarged. This leads me to believe these wheels have porosity and tubes were installed as a "bandaid" cure. I have welded and machined the valve stem holes back to correct dimensions and the wheels are almost ready to be returned to service.
    Does anyone out there make a product I can use to coat the inside of these wheels to cure any porosity they may have? How have others fixed this problem? All advise appricated! Bill
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: C2 wheel porosity......
    Bill,
    I'm not making the same connection as you with regard to enlarged valve stem holes. I believe an intertube stem would fit through a regular sized valve stem hole just fine. (I don't know why anyone would enlarge the holes)
    I'd put a set of tires on them and see how they hold air before coating them them with anything.
    good luck,
    tc
    • Wayne K.
      • December 1, 1999
      • 1030
      Bill,
      As a rule I think that an alloy wheel has a tendency to lose air over time more so than a steel wheel. It could be that whoever installed the tubes just didn't like that characteristic. I also remember some customers when I worked in a service station in the 60's that insisted that we put tubes in tubeless tires because they thought that was safer. As Tracy has suggested it just might be that there is nothing wrong with the wheels unless you know for sure differently. We never had to change the hole size to install tubes in any wheels that we put tubes in.
      Wayne
      • John Daly
        • Bill W.
          • November 1, 1977
          • 402
          Tracy/Wayne, You may be right, I have not mounted a tire to test these wheels ability to hold air. The only way I can account for the enlarged holes is by someone adding tubes. The owner does remember some problems with these wheels, but isn't sure what was done to them. They have been off the car for many years.
          Bill
          • Bill W.
            • November 1, 1977
            • 402
            John, I was not aware the General had a repair kit for porosity problems. Thanks for posting this! Unless someone comes up with a better solution, I think my next move is to test these wheels and apply GM's sealant as needed. Bill
            • Michael H.
              • January 29, 2008
              • 7477
              Bill,
              Many years ago, I learned about what was supposedly the first 64 to roll off the assy line with KO wheels. I don't remember the owners name at the moment but I'm sure others will remember. He purchased a silver blue FI coupe with KO wheels. The dealer eventually informed him that the order was being held up because of the wheels. The problem was indeed porous castings. Somehow, he was able to have the order pushed through and the car was delivered with the KO wheels but, according to the owner, left the plant with tubes installed in all five tires. This car is a very low mileage one owner that was shown at the Bloomington Gold event years ago. Still had the original wheels and tires on it when I judged it. (some time in the early 80's) If I remember correctly, there was paperwork to support his claim. I think his name was Alan and he probably still has the car to this day. Lives in central Illinois?
              Not sure about this but I seem to remember that tubes for 15" tires had the large size stem which would have required larger holes in the AL wheel?
              • Mike McKown
                How many points deduct for tubes? *NM*
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Re: How many points deduct for tubes?
                  Interesting question. I really don't know because I would have been the engine/compartment judge at that time. Now that you mention it, I have to wonder if the tubes were ever seen and points deducted?
                  • Christopher R.
                    • March 31, 1975
                    • 1599
                    Common problem in the aerospace industry. See MIL-STD-276. Your tax dollars at work. This may be too much for this problem. Ask tire and wheel places.
                    • Mike McKown
                      We used to use a product available through
                      Rotunda (Ford). It was a two part epoxy probably much like JB Weld. It's purpose was to seal porous automatic transmission cases. I dont' know why something like that wouldn't work. The problem would be finding the leak if it was tiny.
                      • Mike McKown
                        I've never used them but it seems
                        the valve stems that are held in place on the back side with a threaded nut have a larger hole than a standard tubeless stem. Could this be it? Maybe he had problems with the stems sealing. There are different diameter tubeless stems also.
                        • Wayne P.
                          • August 31, 1975
                          • 1025
                          Re: I've never used them but it seems
                          If you don't want to smear epoxy all over the place and you only have a few small holes, here is the easy, clean fix. When you locate the leak, just peen it with a sharp punch. I've done this many times on newer model aluminum wheels and it always worked.
                          • Jimmy G.
                            • November 1, 1979
                            • 977
                            Call John Ballard. He can recommend a coating (paint) to seal the aluminum. It should be a simple process just like sealing a basement wall from water leaks. I would think a high build epoxy priner should work to solve this problem. Ask John 502-426-2184.
                            • Bill W.
                              • November 1, 1977
                              • 402
                              Thanks for all the suggestions. After considering the problem, I think I'll skip mounting 5 tires and leak testing, then dismounting and leak fixing. I am fairly sure these wheels are leakers and that the easiest way around it is to seal all five before mounting tires. This may take awhile as the owner is busy with other projects, but I'll try to learn how sucessful this it and post an answer later. Thanks again! Bill
