air filter base - NCRS Discussion Boards
air filter base
  • Dale S.
    • November 12, 2007
    • 1224
    air filter base
    In the 70,s I purchased an AC air filter for my 67 C-2 327 K-19. Since the base was wrong, I only used the top and filter(darn it). The base has 3 holes in it with rubber plugs in them. It has one hole(driver rear)that looks like the crankcase breather pipe would go there. Then one on the front passenger side,looks like the K-19 pipe would fit it. The third plugged hole is in the rear on the passenger side. It is the same size as the other 2. Does anyone know what it is made to fit? The top and filter are the same as my C-2.Thank you Dale
  • Mark G.
    • March 1, 2001
    • 227
    • Dale S.
      • November 12, 2007
      • 1224
      Re: air filter base
      Thanks Mark. D/
