72 shouldler belt bolt - NCRS Discussion Boards
  • Ken C.
    • August 31, 2006
    • 120
    i have 2 sets of bolts sitting around, need to know which one is correct for mounting should belt retractor. on a late model 72 convertible
    1st ones have L.L. marking on a slightly domed bolt head, 2nd has same L.L. marking, but on a flat bolt head. also slightly shorter in length then 1st bolt.
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 72 shouldler belt bolt
    How many bolts do you have in each set? I'm unfamiliar with the 72 retractor set-up, but it's bound to have four bolts for the lap belt ends, and two for the shoulder bolt end mounting.
    • Ken C.
      • August 31, 2006
      • 120
      i've already got the seat belts in. But i had the earlier mentioned bolts left over. They were in a bin with bolts from my 72, i also had a 71 and some older SS seat bolts. So only the shoulder belts in question
      • Harmon C.
        • August 31, 1994
        • 3228
        The bolts I usally see in this location have the domed head.
        Lyle
        Lyle
        • Ken C.
          • August 31, 2006
          • 120
          thanks lyle,
          i found my photos i'd taken while taking about interior. i have the domed hex heads but they wouldnt tighten up snug. now i see where i took off a washer during that time and misplaced that. So need 2 washers to mount snug. if anyone has please let me know. or even size would help.
          thanks
          • Harmon C.
            • August 31, 1994
            • 3228
            Ken
            The design of the bolts was so the retractor could pivot to line up with the seat. If you are installing washers their was none on originally that I know of as the threads on the bolt should bottom out on the nut and leave the retractor so it could move a little.
            Lyle
            Lyle
            • Ken C.
              • August 31, 2006
              • 120
              i just reviewed the aim manual and it show a washer in the shoulder bolt, If i use the original bolts i have a little bit of play enough the wobbling while driving can drive u nuts. In 72 aim, UPC1, Sheet F30 on view A, shows a washer #3954735. I figure the washer would along me another 1/8 in. to snug down.
              i'm looking at a set off a 71 retractor (shoulder belt) and the pattern in the area for the bolt looks like it had a washer there, perfect round pattern vs hex head pattern on it. Thanks for help lyle and anything u can find out about this washer would be great.
