C2 body shimming? - NCRS Discussion Boards
C2 body shimming?
  • Dick G.
    • May 31, 1988
    • 681
    C2 body shimming?
    When I put the body back onto it's chassis, should I mess with the radiator support shims are do those after the body is back on? DG
  • Rob A.
    • December 1, 1991
    • 2126
    Re: C2 body shimming?
    Dick,
    If you kept tract of the shims at each body mount, AND are going to put the same number back at each location, I would mount the support to the body before putting it on the frame. You can slide the shims under the support afterwards. Some radiator support shims were tach welded in place.
