53 - 54E Master Cylinder Revisited - Roy & Mike - NCRS Discussion Boards
  • Russ U.
    • April 1, 2004
    • 345
    A few weeks ago, I purchased an item described as a "Buick" master cylinder on ebay. The item appeared correct for 53-54E Corvettes. I received the master cylinder today, and everything looks right to my untrained eye (except for the fitting at the end).
    Relevant #'s:
    Casting# - 5450233 (233 are enlarged on the inboard side)
    Plug# - 5454350 and model # 320-H (JM says that some master cylinders had these #'s)
    Cap# - 5300880
    I have posted pics at the web address below.
    What do you guys think - is this the real deal? My 54 has the original master cylinder, and I was looking for a backup unit to put on. But this one looks just like my original.
    Russ
    1953-54E Master Cylinder
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 53 - 54E Master Cylinder Revisited - Roy & Mik
    (except for the fitting at the end)???. Looks OK great for a back up!
    • Michael L.
      • July 31, 2005
      • 562
      Russ, it looks just like the 53-55 master cylinder. I don't think the casting number is right, but it appears to be the same other than the fitting and number. It looks like it would be a good back up part.
      Mike
      • Bernard M.
        • August 31, 1994
        • 341
        5454350 is listed in my 1950-1965 GM interchange manual as being used on 1954 and 1955 Buicks w/o Power Brakes.
        • Roy B.
          • February 1, 1975
          • 7044
          (GM interchange manual )that is a must for every one Like the JM
          • Don S.
            • February 1, 2000
            • 476
            Where does one get the GM interchange manual
            • William C.
              • May 31, 1975
              • 6037
              They show up periodicaly on eBay, I believe there are also some available as reprints.
              Bill Clupper #618
              • Bernard M.
                • August 31, 1994
                • 341
                They were used by salvage yards. They were published annually. Mine is a 1950-1965 published by Auto Interchange Systems, Las Vegas, NV, a division of Auto Business Forms, and copyrighted 1979. I didn't know any had been reproduced as Bill suggested, but I doubt they're available in print currently anywhere.
