CI rear diff metal tag - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I have a 61 with a metal tag mounted under a nut for the rear end. The tag is round with a quarter of it cut out. Can anyone tell me what the tag signifies? Jerry
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    It signifies the rear end gear ratio, but I don't
    have my chart handy to give you a reading on yours. I think C/C catalog may indicate what ratio a tag shows.
    • Verne Frantz
      Re: It signifies the rear end gear ratio, but I do
      All of the repro guides that list the ratios corresponding to the metal discs are incorrect. Contact Tom Parsons for the REAL ratios connected with those various discs.
      • Rick C.
        • March 1, 1986
        • 183
        Re: CI rear diff metal tag
        Jerry,
        There was a post on this subject about a year ago. If I'm not mistaken, Mike Ernst said that the round tag with one hole for mounting was used for the 3.36 differentials
        • Gene B.
          • May 31, 1990
          • 144
          I believe the disk with a 1/4 cut out refers to a 2:70 rear end ratio.
          Gene
            Jerry -
            The tag with a pie-slice notch out of it signifies a 3.70 axle.
            • Dennis C.
              • January 1, 1984
              • 2409
              Gene: Don't think 2:70 ratio was available... *NM*
