Holley 3815 Jetting - NCRS Discussion Boards
Holley 3815 Jetting
  • Richard J.
    • August 31, 2005
    • 83
    Holley 3815 Jetting
    I am working on my Holley 3815 from my 1967 390hp K19 car and found #71 jets installed. The car runs quite rich and I can't see anything else wrong. I have no power valve issues as that area is completely dry. Does anyone have a Holley book or know these carburetors well enough to tell me if these are correct? I think they should be #67's but I could be all wrong. All help is greatfully accepted. Kindest regards to all, Rick
    Rick Jones
    Albuquerque, NM
    Member #44319
  • William C.
    • May 31, 1975
    • 6037
    Re: Holley 3815 Jetting
    Primary .067, Sec .073 per the '67 Chassis service manual. Sounds about right from some experience with Holleys.
    Bill Clupper #618
    • Jim T.
      • March 1, 1993
      • 5351
      Rick if you have the carb apart a vacuum test on the power valve will verify the power valve is OK. A replacement single power valve can be purchased from various automotive stores. All it takes is a stumble/backfire starting the engine or taking off from a stop sign to rupture the power valve. A quick test after an occurance of this is to remove the air cleaner lid and put a finger over the vertical vent. If the engine dies right away, the power valve is not being held closed with engine vacuum. Using Holley's since 1974 this simple test has always worked for me.
      • Gerard F.
        • June 30, 2004
        • 3806
        Holley book indicates #67 primary jets, no secondary (#17 metering plate for 4160 carb)
        Jerry Fuccillo
        #42179
        Jerry Fuccillo
