1962 Radiator - NCRS Discussion Boards
1962 Radiator
  • Richard H.
    • January 1, 1999
    • 32
    1962 Radiator
    Did all Harrison radiators have the serial number stamped into the radiator? Does the word Harrison appear anywhere on the radiator? If the metal tag has model number and date, is the model number also stamped directly into the radiator? I have a chance to buy a so called original radiator for my March car that only has the model number stamped into the radiator, no date. Could I install a metal tag to make this radiator correct for my car?
    Thanks alot.
    Deb
    Re: 1962 Radiator
    Deb -
    I don't think I'd spend a lot of money for an original '62 radiator, if indeed it's "original" - it's LONG past its service life, and is not repairable when it starts to leak.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Deb, Believe I would contact DeWitts, who...
      ...beautifly reproduce 1962 radiators. They can answer your questions and also give you a quote on a new radiator. I don't mind buying used parts, but old radiators are something I avoid since a new part is available.
      • Mike E.
        • February 28, 1975
        • 5139
        Re: 1962 Radiator
        Deb, if you did put a metal tag on it, it likely wouldn't receive full credit in judging. By that point in 62 production, the foil tag was put on the radiators and the date was stamped on the left side near the part number.
          • 43238
          Re: Deb, Believe I would contact DeWitts, who...
          Dennis, John, and Deb------
          I TOTALLY agree! Buying a used radiator like this is a "crap shoot" and you'll likely come up "crapping out". Even if the radiator has no leaks now, how long will it be before it starts leaking and becomes useless?
          DeWitts is the ONLY way to go. Thank God that there is a DeWitts!
