REAR LEAF SPRINGS CORVETTE 1957 - NCRS Discussion Boards
  • Lars A.
    • June 30, 2004
    • 28
    Does anyone know what the correct rear springs shoulb be for my 1957?
    Whats the difference between the 1958 and 1957 rear springs?
    I have rear springs with part number 3711550, is thats correct?
    Also on the main spring at one of the end it has a curve - its that correct?
    Many THX
    Lars
  • Roy B.
    • February 1, 1975
    • 7044
    Re: REAR LEAF SPRINGS CORVETTE 1957
    You could "use" the spring from any 53 to 62 Corvette, there were 4 and 5 leaf used
    • Kent D.
      • February 1, 1992
      • 100
      If the curve that you are talking about is a reverse curve at the front of the spring then it is bent.
      • Jacob A.
        • December 1, 2003
        • 237
        I am certainly no expert... but doesn't the 57 spring have a groove in it?
        • Terry D.
          • May 31, 1987
          • 2696
          Lars
          That's the correct number for 56-57 rear springs. They had four leafs. Later springs have part number 3751438 stamped on them along with a date code from Eaton Spring. 5 leafs was a one or two year heavy duty suspension option, you don't want that unless you want to ride in a really ridig car. As far as I know they all had grooves in them. No repos have the grooves. Hope this helps.
          PS Eaton will redo your springs, they are in the Detroit area.
          • Dave Suesz
            Terry is right...
            The original springs had a grooved leaf, no repro does. These must be renewed by experts, as they need to be annealed, curved, and heat treated to maintain correct shape. If they are recurved cold, the'll just go bad.
