'67 L79 oil filter adapter - NCRS Discussion Boards
  • Joseph E.
    • March 1, 2006
    • 175
    The spin-on style filter someone had installed has been removed and I'm ready to install the correct style oil filter adapter. Is there supposed to be a gasket between the adapter and the block or does it bolt up bare? Member input is most appreciated, as always. Thank you.
    Joe
    #45420
  • Phil P.
    • April 1, 2006
    • 409
    "o"ring should have come with the new filter *NM*
      • 43238
      Re: '67 L79 oil filter adapter
      Joe-----
      Actually, 1967-only did use a gasket between the adapter and the block. No earlier year Corvette did, though, and somehow they all survived alright. All the other parts were the same. Anyway, the gasket was GM #3903322. It was discontinued years ago without supercession. I don't know if it's reproduced, or not. I don't think that it would be too hard to make from gasket stock, assuming that you choose to use it.
      • Dale S.
        • November 12, 2007
        • 1224
        Joe, I bought a repro when I went back from a spin on to the correct canister. I dont remember who had it, but I did not reuse the original. Dale
        • Donald M.
          • December 1, 1984
          • 498
          I used a gasket that I traced and cut out of gasket stock. Been on the engine for 15 yrs. without any problems.
          Don
          • Brandon K.
            • April 1, 1997
            • 474
            Long Island Corv Supply repro's the gasket. I would assume most of the others do as well.
