C1 Window Regulators - NCRS Discussion Boards
  • Pierre J.
    • July 31, 2000
    • 193
    The splines, in crank shaft in my '57 window regulator, are worn out and I need to replace it. It is part of a small shaft/gear assembly that is riveted to the main part of the window regulator.
    Does anybody know where I can find on of these? Are they the same as a full size Chev. or any other GM products.
    Pierre 34410
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Window Regulators
    55 to 57 is one and may be others?
    • Roy B.
      • February 1, 1975
      • 7044
      • Pierre J.
        • July 31, 2000
        • 193
        Roy,
        I'm not sure what you're saying.
        Are you saying 55 to 57 Corvette window regulators are the same? or they are the same as other GM products?
        I thought all C1 had the same regulators.
        Pierre
        34410
        • Pierre J.
          • July 31, 2000
          • 193
          Roy,
          Pierre
          34410
          • Roy B.
            • February 1, 1975
            • 7044
            Sorry guy! 56 to 60 Corvette are all the same but PW doors, also the (Pontiac and Chevy Nomads) are the same as Corvette even the PW types, I was talking the gear area you spoke about same as many cars.
            • Roy B.
              • February 1, 1975
              • 7044
              • Roy B.
                • February 1, 1975
                • 7044
                You are asking about the handle gear (little one )not the whole assy .I was talking about the whole assy
                • Roy B.
                  • February 1, 1975
                  • 7044
                  • Mike E.
                    • February 28, 1975
                    • 5138
                    Pierre--
                    Roy is incorrect-- 56 through 58 Corvettes used the same window regulators--59 through 62 used another, because the crank handle was relocated slightly. The only difference is in the location of the bend and angle of the bend in the long arm--and that's only inside the door--not visible outside. GM products of that vintage used very similar mechanisms with necessary changes to fit the doors and the window channels--but the small gear you need should be available in many of those. There is a lot of restriction against the gears when the window is maladjusted--but usually that will first bend the arm, and then strip the teeth from the larger gear. If you have no luck, email me offline, and I'll see what I have in old regulator parts. I'd guess I have something, but we got 12" of snow today, and I'm not eager to go out to the barn tonight and look.
                    Regards, Mike
                    • Mike E.
                      • February 28, 1975
                      • 5138
                      Pierre--
                      Regards, Mike
                      • Pierre J.
                        • July 31, 2000
                        • 193
                        Thanks for the clarifications Mike. I have one more place to check next week and if I come out empty, I may take you up on your offer.
                        12 inches of snow??? Freezing rain here.
                        Pierre
                        Ottawa Canada
                        • Pierre J.
                          • July 31, 2000
                          • 193
                          Pierre
                          Ottawa Canada
                          • Roy B.
                            • February 1, 1975
                            • 7044
                            Re: C1 Window Regulators Mike Thanks *NM*
                            • Roy B.
                              • February 1, 1975
                              • 7044
