'57 - 245 hp - NCRS Discussion Boards
'57 - 245 hp
  • Brian W.
    • September 30, 1990
    • 216
    '57 - 245 hp
    I have an early '57 build date Oct. 12/56; dual 4 barrel carbs, tag #2419S and 2362S. The rear air horn has cast #6-1310. Can anyone tell me what this belongs to and what would be correct for my car? Thanks
    Brian
  • Joseph T.
    • April 30, 1976
    • 2074
    Re: '57 - 245 hp
    I believe the correct airhorn was #1299 and the main body 049..others can correct me if thats not right.
    Joe
    • Joseph T.
      • April 30, 1976
      • 2074
      Re: '57 - 245 hp
      Joe
      • Rob Dame
        Re: '57 - 245 hp
        Per Colvin's book the 2362 S & the 2419 S on an early 57 would likely have a
        6-1151 or 6-1156 air horn and a 049 bowl. I don't find the 6-1310 horn listed so it is probably from a pass car. Rob
        • Rob Dame
          Re: '57 - 245 hp
          • Brian W.
            • 216
            Re: '57 - 245 hp
            Thanks again. The body is 049 so now I know what to look for.
            • Brian W.
              • 216
              Re: '57 - 245 hp
              • Rod K.
                • 443
                Re: '57 - 245 hp
                Brian,
                '56-'57 Judging Manual states "1957 Air Horn casting 6-1151 is possible but not likely. 6-1156 and 6-1203 were used on 1956 style carburetors...until about November 1956..." Also "The last known use of 6-1151 was in August, 1956 carburetor production." Since you stated "tag numbers" in your original post, the date code on the tags may help to pin this down for you.
                Hope this helps.
                Rod
                • Rod K.
                  • 443
                  Re: '57 - 245 hp
                  Brian,
                  Hope this helps.
                  Rod
