Where is the best place to get CORRECT tie rod ends with grease fitting on the side and correct rubber seal? Thanks in advance.
C-1 Tie Rod Ends
Re: C-1 Tie Rod Ends
early Chevy used the same and has many parts that exchange with Corvette- Top
I have some correctly made C1 tie rod assemblies. The tie rod ends have the proper zerk fitting locations and fittings are correctly cad plated. The assemblies have correctly marked and cad plated TR bolts on the clamp assemblies although they are about 1/16" longer than originals. Hardware and cotter pins are also cad plated. Boots are later version shaped like an umbrella rather than the early inverted funnel shape. I have the assemblies painted and unpainted. Email me if you need more information or see http://www.ckautollc.com/parts.HTML- Top
