Harmonic balancer - NCRS Discussion Boards
Harmonic balancer
  • Paul K.
    • February 1, 2002
    • 160
    Harmonic balancer
    I pulled this balancer off my 427/390 it is a 7" Cast # _880060 the first number was cut by a hole other numbers are T, GM8,
  • Paul K.
    • February 1, 2002
    • 160
    Re: Harmonic balancer
    Can anyone tell me what this 7" harmonic balancer is off of Cast #_880060
    • Paul K.
      • February 1, 2002
      • 160
      • Tom D.
        • September 30, 1981
        • 2135
        Re: Harmonic balancer 390 HP 427
        I have one off a 427 "T1205IL" service replacement engine with the same number on it. Photo exists somewhere...
        Tom Dingman
        4889
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • Tom D.
          • 2135
          Tom Dingman
          4889
          Michigan Chapter
          Tom Dingman
          • Terry F.
            • September 30, 1992
            • 2061
            As I recall, that part number appears correct for 7 inch 390 hp. Look closely at the front and tell me what is stamped in the front. Terry
            • Terry F.
              • 2061
              • Wayne M.
                • March 1, 1980
                • 6414
                7" dia. hydraulic C2 BB's
                # 3860060, which doesn't appear under Gr 0.659 in the parts manuals, so I suspect that this casting # is just for the center hub. The assembly (incl. ring and rubber damper is listed as # 3860010.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                    • 43238
                    Re: 7" dia. hydraulic C2 BB's
                    Wayne-----
                    That's what it is; it's just the casting number for the center hub. It's not a finished part number and was, of course, never available seperately. It may not even identify the complete balancer that it's part of since it may have been used for more than 1 finished balancer.
                      • 43238
                      Wayne-----
                        Paul -
                        I have the drawing for the 7" hydraulic-lifter 427 balancer, P/N 3860008, and it shows a callout for the center hub portion of the assembly as 3860060.
                          Paul -
                          • Paul K.
                            • February 1, 2002
                            • 160
                            Thanks for all your help. its a great place to post a question.
                            Paul klemetson
                            • Paul K.
                              • February 1, 2002
                              • 160
                              Paul klemetson
