1963 early SWC - NCRS Discussion Boards
1963 early SWC
  • Stanley D.
    Infrequent User
    • May 31, 2006
    • 9
    1963 early SWC
    Hi
    Can anyone provide info or tips on how to correctly install stainless steel staples to secure the rubber dust shield onto the metal fan shroud. Do they fold in or to the bottom side?
    Stan
  • Arnold P.
    • August 31, 2005
    • 48
    Re: 1963 early SWC
    the staples are driven from the bottom of the shroud into the seal and crimped on the top of the seal. hope this helps,pappy
    • Arnold P.
      • August 31, 2005
      • 48
      Re: 1963 early SWC
      • John D.
        • December 1, 1979
        • 5507
        Re: 1963 early SWC
        Stenley, I don't believe the SS staples will pass NCRS judging though. Also they are much harder to install that the regular steel ones that are readily available for a few bucks from the repro catalogs. John
        • John D.
          • December 1, 1979
          • 5507
          Re: 1963 early SWC
          • Collin MacDonald
            Re: 1963 early SWC
            John,
            Could you please provide which vendors are selling the steel ones? Every vendor I went to had the SS staples....appreciate your help... I had to use some originals that I have been holding and just had enough to get the job done, would love to have second source for these...Thanks
            • Collin MacDonald
              Re: 1963 early SWC
              John,
              • John D.
                • December 1, 1979
                • 5507
                Re: 1963 early SWC
                Collin, I thought that my restorer-Dave Cardina got the staples from Long Island. On the other hand I remember him saying that he had some on stock. Saw a judge at Marlborough though putting his favorite tool on a staple. Luckily the magnet stuck. First time around with my 63 it had SS staples. I will call one thumb-oops- Dave and ask him. He got a nickname of one thumb because he dropped my tranny on it. Luckily he didn't hurt the tranny. Thumb all better now but the trans would never be better from being slammed 5 ft to the floor. His thumb was between the concrete and the case. Ouch. John
                • John D.
                  • December 1, 1979
                  • 5507
                  Re: 1963 early SWC
                    Re: 1963 early SWC
                    I make my own from 16-ga. galvanized steel wire (hardware store blister-pack item) - that's what the originals were (came on 25# spools that fed the air-powered Bostitch industrial staplers).
                      Re: 1963 early SWC
                      • John D.
                        • December 1, 1979
                        • 5507
                        Re: 1963 early SWC
                        Hi John, I heard the same answer for Jorjorian. Cut and form the steel staples from a roll. My job is done but I am sure that Collins will appreciate the answer as well as others. DOn't know why the repro boys don't have the staples made correctly. I can remember many years ago the first time my 63 was restored we used the stainless staples and they were tough to bend. Thanks, John D.
                        • John D.
                          • December 1, 1979
                          • 5507
                          Re: 1963 early SWC
                          • Wayne W.
                            • April 30, 1982
                            • 3605
                            Re: 1963 early SWC
                            John, I dont think that the originals were regular steel wire. It would take spring steel to staple through those panels. If you try to straighten an original that sucker is strong. Those things also went through the metal shields without hole drilling. I once challenged the Boststich rep. to get me a stapler to do them since I do so many. I told him I would buy it if he showed me one that would work. After several visits with different models, he gave up. The finish looks like cold rolled or spring steel also.
                            • Wayne W.
                              • April 30, 1982
                              • 3605
                              Re: 1963 early SWC
