71 Chevelle LS6 - NCRS Discussion Boards
71 Chevelle LS6
  • George Droggitis
    71 Chevelle LS6
    I am the owner of a 67 Corvette and read the board religiously. However, I have a Chevelle question if you don't mind. I looked at a 71 Chevelle yesterday that had a LS6 in it. I have heard that GM produced around 14 of these from left over engines from 70. Does anyone know if this is true? Thanks
  • Jay G.
    • August 31, 1993
    • 398
    Re: 71 Chevelle LS6
    I own an Org. 67 Chevelle SS 396 ragtop. All paper and Build Sheet. ( Unique looks like an IBM punch-card.) I've heard that story as well. Bottom line. The car should have EVERY bit of paperwork to justify the legitmate price a car such as this will command. If not, treat it as it is. A maybe and priced accordingly.
    • Jay G.
      • August 31, 1993
      • 398
      Re: 71 Chevelle LS6
        • 15606
        Re: 71 Chevelle LS6
        The Chevelle guys are still looking for that elusive 1971 LS6 -- if one turns up it will be rarer that a 1969 Corvette ZL1. As Jay says, it better have iron-clad paperwork and owner provenance from build to present day. Any left over 1970 LS6 engines likely would have gone into the service parts operation once the 1971 build began. One can dream, but I wouldn't waste my money.
          • 15606
          Re: 71 Chevelle LS6
          • Steve Antonucci
            Re: 71 Chevelle LS6
            George,
            If you haven't already, go the The Supercar Registry and ask over there as well (www.yenko.net ).
            Select the link: Supercar & Musclecar Bulletin Board
            Steve
            • Steve Antonucci
              Re: 71 Chevelle LS6
              George,
              Steve
                • 43240
                Re: 71 Chevelle LS6
                George-----
                I think that folks looking for a 1971 LS-6 Chevelle are going to be looking for a long time and will still come up "dry".
                Keep in mind that the 1970 model year was the last year for "high compression" engines (at least, for a long while; almost everything comes back eventually). For 1971, compression was lowered to follow a GM corporate edict that all 1971 engines be capable of running on regular fuel (in anticipation of the introduction of regular grade only unleaded fuel). I seriously doubt that GM would have compromised that edict in order to "use up" a few 1970 engines. I think that they would rather have scrapped the engines than do that, but they didn't have to scrap any such "left over" engines. They could simply have transferred them to GMSPO for SERVICE use. I think that GMSPO would have been very capable of "absorbing" a handful of engines. After all, the engines were still available in SERVICE after the 1970 model year.
                  • 43240
                  Re: 71 Chevelle LS6
                  George-----
                    • 43240
                    Addendum
                    Also, keep in mind that 1970 emission control regulations were different from 1971 regulations. Very likely, it would have been completely impractical to install 1971 emission components on a 1970 engine and there may have been no available components for a Chevelle installation.
                      • 43240
                      Addendum
                      • Chris L.
                        • November 1, 1998
                        • 275
                        Re: 71 Chevelle LS6
                        Hey guys.....bet they have at least one at Barrett-Jackson this year!!!!
                        • Chris L.
                          • November 1, 1998
                          • 275
                          Re: 71 Chevelle LS6
                          • Clem Z.
                            • January 1, 2006
                            • 9427
                            GM/ NHRA listed a 454 425 HP,C.I. heads,solid
                            lifter cam engine for chevelles and monte carlos in 1971. CR of 10.1:1. where they built your guess is as good as mine. what is on the stamp pad ??
                            • Clem Z.
                              • January 1, 2006
                              • 9427
