1976 Radiator Shroud replacement - NCRS Discussion Boards
  • Christopher J. Bunsey
    I have an early 1976 L82 with a cracked fan shroud. I have a NOS to replace it with, but want to know what I am getting into, and how best to do it! Any tips would be greatly appreciated!
    Chris
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 1976 Radiator Shroud replacement
    Chris
    Their is no easy way. You have two ways one is remove the RH upper A-arm. You can remove the bolts from the radiator support and tip it forward but if you have A/C you need to remove the vacumn canisters to have enough clearance to pull the radiator and install the shroud.
    Lyle
    Lyle
    • Harmon C.
      • August 31, 1994
      • 3228
      Chris
      Lyle
      Lyle
