Engine Stamp Pad - NCRS Discussion Boards
Engine Stamp Pad
  • Paul G.
    • August 31, 2006
    • 66
    Engine Stamp Pad
    I'm currently in the process of cleaning up and detailing the engine compartment on my 65 coupe. Can anyone suggest the best method for cleaning up the engine stamp pad? It's soiled and has very very light rust.
    Paul
  • Mike M.
    • May 31, 1974
    • 8385
    Re: Engine Stamp Pad
    brass brush with 10w motor oil or W-D 40. be gentle as you only get the factory broach marks once.mike
    • Paul G.
      • August 31, 2006
      • 66
      Thanks Mike, I'll give it a try.
      • Rob A.
        • December 1, 1991
        • 2126
        Paul,
        You can use Eagle brand "etching" mag wheel cleaner. It will only take the rust off and you can protect it from re-rusting with a coat of oil.
        • Allan J. Wicklund
          I'd just leave it as it is soooooo authentic as it stands. JMHO Al W.
