Follow up: 79-77 rear frame conversion - NCRS Discussion Boards
  • Michael B.
    • April 1, 1999
    • 178
    Sharpened air chisel
    3" Cutting wheel on die grinder
    application of patient persuation:
    Successful removal of the 2 rear frame members (rear frame brace where the gas tank straps to) took about 2 hours. Gently cut into the weld beads to allow the air chisel to have some place to bite other than the frame steel.
    Anyone need a 79 rear frame member - fully restored, using John Deere inhibitor and black (man that stuff is tough to take off a sand blasted surface - note, edges are a bit frayed, and the part is located in Canada (Markham).
    Cheers,
    Michael B.
