Radiator advice for 68 L71 - NCRS Discussion Boards
  • Erik S.
    • January 1, 2005
    • 407
    Hello - I did a search in the archives but couldn't find the answer to my question (probably lousy search job but nevertheless);
    I am doing a (insofar possible) NCRS style body off on my 1968 L71 and want to replace the radiator for a DeWitts. What advice would you give me - go for the aluminium
    or take the copper and brass product?
    Your advice and views are highly appreciated (as always),
    Erik
    Re: Radiator advice for 68 L71
    Erik -
    Depends on your objective for the car - the copper/brass will get more judging points, but the aluminum has 25% more cooling capacity. Depends whether you want to watch the scenery or the temperature gauge.
    • Erik S.
      • January 1, 2005
      • 407
      Thanks John - I will check the judging manual how many points I would burn with the Aluminium one.
      Erik
      • Jim T.
        • March 1, 1993
        • 5351
        Erick your post made me check Dewitts site, they make aluminum radiators for 68 BB but did not see an aluminum radiator for a 68 SB, they do have them for the 69-72 SB though.
        • Rich G.
          • August 31, 2002
          • 1397
          My 34K mile 68 L71 has an original copper/brass radiator and has no cooling problems at all.
          Rich
          • Phil P.
            • April 1, 2006
            • 409
            dewitts 63-72 alum rad p/n A63M *NM*
            • Erik S.
              • January 1, 2005
              • 407
              Same here Rich - cooling isn't that big of an issue as well. Maybe the brass version then......
              Erik
              • Mark #28455
                My L89 uses the stock radiator too
                It has a stroker 489 engine (original block and heads) and with all the correct fan, seals and the chin spoiler, it holds a steady 190 - 210 with the 195 degree thermostat in Florida - and no crazy high volume water pump or cooling additives! The factory designed these cars to be driven.
                The interior also holds a steady 190 degrees but that's another story (JUST KIDDING!!!).
                Mark
                • Thomas D.
                  • May 31, 1987
                  • 121
                  The 68 small block could be the BB radiator, if the car had either AC or Auto.
                    • 43221
                    Tom------
                    I'll go even further and say that the 68 small block WOULD BE the BB radiator if the car had either C-60 or M-40.
