ZR1 Brake Problem - NCRS Discussion Boards
ZR1 Brake Problem
  • Charles A.
    • July 31, 1980
    • 180
    ZR1 Brake Problem
    I acquired a 90 ZR1 that sat for 7 years. Put in new brake fluid by bleeding at each wheel. After driving for 15 minutes brakes locked up and brake pedal became very hard. After sitting for 20 minutes problem went away. Thought it was just rear brakes with pistons sticking so I replaced rear calipers. Drove again and same problem with the front brakes and possibly still the rears but both fronts definitely locked up. After cool down everything works fine. Anyone have a diagnosis and solution? Thanks Chuck.
  • Clem Z.
    • January 1, 2006
    • 9427
    the inside of the flexible lines could be causing
    the problem as they get pin holes in the inter lining and the pressure of applying the brakes will cause to expand blocking the return of the fluid. a friend had this happen to his corvette and the brakes got so hot there was a fire
    • Charles A.
      • July 31, 1980
      • 180
      Re: the inside of the flexible lines could be caus
      Sounds scary but Not such a hard fix hope you are right.
      • Mike M.
        • May 31, 1974
        • 8385
        agree with clem. good luck. mike
        • Charles A.
          • July 31, 1980
          • 180
          Thanks guys since the pedal gets very hard and goes down some have advused it could be a vacuum problem. Also problem goes away 10 minutes after sitting. Any thoughts on a vacuum issue?
            I'd bet on deteriorated flex hoses becoming check valves.
            • Jim T.
              • March 1, 1993
              • 5351
              It has happened to me, no fire but lots of smoke coming from the right front, thought it was on fire. Drove it to work that morning and going home it just happened. Thought it was the caliper at first, even replaced the caliper like you. Wasted time and money. Having to replace one hose the rest were just as old and replaced all of the rubber hoses.
              • Charles A.
                • July 31, 1980
                • 180
                Only thing that makes me think something different is all four lock at once. If it were lines seems like it would just be one or two. Could the vacuum assist check valve be a problem or a clogged return on the master cylinder?
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  is the MC pushrod adjustable,i could be too long and heat expansion taking over.
