c1 283 V8 & TH350 - NCRS Discussion Boards
c1 283 V8 & TH350
  • Mark Radin
    c1 283 V8 & TH350
    Is there anyone who can "talk" to me about hooking up a 283 V8 & TH350.
    Mark
  • Verle R.
    • March 1, 1989
    • 1163
    Re: c1 283 V8 & TH350
    Mark,
    The TH 350 will bolt up fine with the normal 350 CU IN flywheel.
    This answer does not adress the rear mount.
    If you are going to go to the trouble to change, install a 200R4 and get an overdrive also.
    Verle
    • mike cobine
      Verle has a good suggestion with the 200R4. Since 283s used lower final drives than other engines like 327s and 350s due to lower torque, the gas mileage can be improved greatly with an overdrive.
