THE BLOWER MOTOR IS STUCK ON LOW ITS NOT ENOUGH TO DE FOG THE FRONT WINDOW WHEN I NEED IT..I REPLACED THE BLOWER MOTOR RESISTOR AND IT STILL STUCK ON LOW SPEED.. WHEN I MOVE THE SWITCH FROM LOW TO HIGH I CAN HEAR A PING SOMETIMES BUT IT STILL NEVER GOES ON HIGH SPEED ANY HELP OUT THERE...THANK YOU IN ADVANCE
C-1 BLOWER SWITCH
Re: C-1 BLOWER SWITCH
Jack,
You'll probably get more help if you quit shouting (all caps). Generally the problem is with low speed--that's where the resistor comes in. You'll have to take the switch apart and make sure that the contacts are making contact, otherwise there's not much to tell you.- Top
