Ok I need some support here - NCRS Discussion Boards
  • John M.
    • January 1, 1999
    • 1553
    Re: Ok I need some support here
    Been picking them up like this for many years, and have never given it a second thought.
    Your post however, got me to thinking, and I looked up the tensile strenght of several grades of bolts. Grade 2 in this size will have a 55,000 PSI proof strength, Grade 5 will have 85,000, and Grade 8 will have 120,000.
    I then calculated the crossectional area of a 1/4" bolt at .049 Square inches.
    The proof strength of a single bolt would be 2700 pounds for a Grade 2, 4165 for a Grade 5, and 5850 pounds for a Grade 8.
    If you multiply this times 4 for the 4 bolts, you will find that even with crappy Grade 2 bolts, you will have a proof strength of over 10,000 pounds of load. Even if you assume that the threads in the manifold are not in perfect condition, you will still have a load ability of over 5,000 lbs, or roughly 10 times the weight of a smallblock engine! With Grade 8 bolts, the load capability of these 4 bolts will exceed 20,000 lbs.
    Pick it up by that carb plate, and don't give it a thought, like I did for years! LOL
    Regards, John McGraw
    • Loren L.
      • April 30, 1976
      • 4104
      Like the others, I don't think it is a
      problem, but if looking at your setup sets off warning bells, how about 2 chains, each going to two of those 3/8" bolts that hold the exhaust manifolds on.....
      • Dick W.
        • 10483
        #18
        Dito to what most say. No problems with a lift plate. I have used them on a lot heavier engines that a 454. Ever see a V-549 International. Over 1,000# fully trimmed out. More worried about the hoist that the plate.
        Dick Whittington
        • Chris S.
          • January 1, 2000
          • 1067
          #19
          never had a problem with a lift plate
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
          • Roy B.
            • February 1, 1975
            • 7044
            #20
            Re: Ok may have bad holes
            I dont think I'll chance having bad holes so I'll just do it my way
            • Tracy C.
              • July 31, 2003
              • 2739
              #21
              I'm with the pucker crowd on this one ...
              The bolts aren't what concern me, it's the threads in the cast aluminum intake that I worry about.
              I normally use longer bolts through the corners of the intake that anchor into the heads.
              tc
              • Mike M.
                • May 31, 1974
                • 8389
                #22
                not to worry tc, if ya borrow the neighbor's hefty heifer and place the ole damsel under the engine as you lift it with the plate. mikie
                • Chuck R.
                  • April 30, 1999
                  • 1434
                  #23
                  Re: Well? heres the way I see it
                  First of all, thanks for all the posts pro AND con
                  As my 350 has 1967 heads on it, I'm pretty confident that the heads will NOT have the bolt holes for Joe's lifting brackets, so I can probably discount that option.
                  Guess I'll bite the bullet and try the lifting plate.
                  It's tough not to revert back to the old school ways, but this ain't no 454 buss engine either.
                  Thanks again to all.
                  Chuck
                  • John M.
                    • January 1, 1998
                    • 813
                    #24
                    Chuck if the threads in the aluminum are Ok and you do the calculations, at about 50 % of yield, each bolt and thread will hold about 1100lbs. I'd say it's pretty safe.
                    • Chuck R.
                      • April 30, 1999
                      • 1434
                      #25
                      Re: Just how heavy IS a 350?
                      All dressed out from pan to carb and fan to pressure plate?
                      • Terry F.
                        • September 30, 1992
                        • 2061
                        #26
                        Patrick,
                        Just a suggestion. If you are going to attach a steel tab to the engine, you should use bolts that can be tightened all the way down so the steel tab won't move and the bolt has some torque on it.
                        There is a tendency for the threads to get screwed up the way you are doing it. The long bolts you are using are acting like a lever and pulling laterally on the bolt hole. The lifting and swinging motion of the engine can put a lot of wear in a short period of time on those threads. Also, I can't stand leaking intake manifold bolts.
                        Just my humble opinion. Terry
                          Chuck -
                          About 550# with the flywheel and clutch.
                          • Chuck R.
                            • April 30, 1999
                            • 1434
                            #28
                            Re: Thanks John
                            Guess I should still keep the toes out of the way then huh?
                            Chuck
