Intake Rivets C3 - NCRS Discussion Boards
Intake Rivets C3
  • Sheldon S.
    • March 1, 1999
    • 475
    Intake Rivets C3
    I recently ordered some of the rivets that hold the oil splash pan on the underside of the intake manifold for my 71 BB 454, cast iron manifold. When I started to remove the splash pan I noticed that the pins that I took out are more of a split rivet and the new ones I purchased GM#10229247 are not split but have fine splines on them. Are these correct to use for my application and any special installation instructions?
    Thanks in advance
    Sheldon
  • Clem Z.
    • January 1, 2006
    • 9427
    i would put a little red loctite on them . some
    people drill and tap for machine screws but i any case use the loctite. if they drive in tight they should stay in place
    • Terry F.
      • September 30, 1992
      • 2061
      Re: Intake Rivets C3
      If they require gental tapping with a hammer into the holes and are the correct length, they will work. Terry
      • John M.
        • January 1, 1999
        • 1553
        I would never put rivets back in the holes. Nobody will ever see them, and I feel a lot better knowing that there are screws in there with red loctite on them!
        Regards, John McGraw
        • KEN BUTCHER
          Terry's right, if you took the old rivets out gently, the new rivets just have to be tapped in with a hammer.
          • Terry F.
            • 2061
            I agree, if you want to make it bullet proof. Put some machine screws in there. Tap the holes and screw them in. But, I am comfortable with the way GM did it. Take care, Terry
