68 Driver side door mirror - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Where is the best place to get a factory correct date coded mirror for the driver door of my 68?
    The mirror I have has a date code of 10 DMI 4 which makes it an October 1974 and I need to purchase a mirror coded for 1968 to pass judging?
    Thank you,
    Kurt
  • Kent K.
    • December 1, 1982
    • 1139
    Try CC, Paragon, other big vendors *NM*
    Kent
    NCM Founder - Member #718
    • Rick S.
      • January 1, 2003
      • 1203
      Re: 68 Driver side door mirror
      Kurt,
      I believe that Paragon sells just a correct dated mirror glass so you don't have to buy the entire mirror.
      Rick
        • 11642
        Correct.
        They sell the mirror with plan glass, with dated glass, or just the dated glass.
        Patrick
        • Rick S.
          • January 1, 2003
          • 1203
          Patrick,
          Where have you been lately? Deer hunting by driving the back roads in your Vette looking for deer?
          • Kurt B.
            • July 31, 1996
            • 971
            Paragon only sells the replacement glass for 78 and up; not 68 accordign to their latest catalog # V.31.2006
            Kurt
            • Kurt B.
              • July 31, 1996
              • 971
              Patrick,
              Do you have a part number for just the dated glass on a 1968, because I cannot find it in their catalog any longer. They have the later years but not 68.
              Kurt
              • Dick W.
                • 10483
                Give OEM glasss a call. 800-283-2122. They used to be THE source for dated mirrors.
                Dick Whittington
                • John C.
                  • January 1, 2005
                  • 616
                  Kurt
                  Make sure you have the correct mirror head size for a 68. 68-74 used a small mirror and 75 and up a larger. From the date code you give it is probably a large head mirror.
                  John
                  • Kurt B.
                    • July 31, 1996
                    • 971
                    John,
                    The mirror head size is 3 7/8 by 5 3/8 with a glass size of 3 1/2 by 5.
                    I know what you mean about the late date code; one would expect it to be the larger size. It's strange and I can't explain it.
                    Kurt
                      • 11642
                      What do you mean?
                      I'm here daily. My Corvettes haven't moved since mid May, so no problem with hitting deer when they spend all their time in storage.
                      Patrick
                        • 11642
                        Kurt,
                        It's right there...
                        http://www.corvette-paragon.com/cata...5-4BB501F401D8
                        • Kurt B.
                          • July 31, 1996
                          • 971
                          Thanks Patrick.
                          I found it with your link but it was not in the catalog.
                          I will call and order tomorrow along with other items I need.
                          Kurt
                            • 11642
                            No problem.
                            I've purchased them, and even saw them at Carlisle, so I knew the glass was available.
                            Patrick
