transmission removal - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5186
    I am pulling the transmission out of my 63 and the service manual say's to insert two studs in the top holes of the transmission to aid in removal and keep the clutch disc from being damaged. Can anyone tell me how long to make these studs so as to completely get the input shaft out of the clutch disc.
    Thanks in advance
  • Mike M.
    • May 31, 1974
    • 8388
    Re: transmission removal
    6 to 8 inches long.mike
    • Mike M.
      • May 31, 1974
      • 8388
      PS use all thread.mike
        I use 1/2" shank bolts with the heads cut off, then rounded off, and hacksaw a screwdriver slot in the end to ease removal. Don't forget to plug the output shaft to keep the lube in the tranny (that's the orange plastic thing).
        • Timothy B.
          • April 30, 1983
          • 5186
          Mike and John, Thanks for your help
