Birthday question - NCRS Discussion Boards
Birthday question
  • Brian K.
    • May 31, 2004
    • 358
    Birthday question
    Here a question, I've got a 66 AO smith build convertible the trim tag date is G23 which I think is March 23. The Birthday calculator came back with March 5th for its vin of 15736. the engine stamping is F0224HT with a casting date of either B-13-6 or B-18-6. My question what is the build date of this car? Whats the G23 mean? Thanks for any help. sincerely Brian
  • Donald L.
    • September 30, 1998
    • 461
    Re: Birthday question
    If Im not mistaken the A month for AO Smith 66 model is Aug. G being the 8th month would be Feb so a G23 trim tag date is Feb 23.
    • Rob M.
      • April 30, 2003
      • 657
      Brian,
      I might be wrong, but I pretty sure that an AO body build of G23 would be February 23 not March 23. The letter representing the month was different for AO than StLouis. If you had a St Louis car it would be March. So, your numbers look good.
      Rob
      Rob
      '66 327/300 Regional Top Flt
      '08 6 speed coupe
      • Michael H.
        • January 29, 2008
        • 7477
        Donald,
        You are correct. The Smith plant used A for august while the St Louis plant used A for September.
        • Brian K.
          • May 31, 2004
          • 358
          Thanks everone for answering this question. I knew the engine was original as the car has been in the family since 1973, just didn't understand the G23 thing. Thanks again (what a great board) sincerely Brian
