wooden engine support - NCRS Discussion Boards
  • don izzo
    I have been searching the archives for the sketch of that home made wooden engine support that goes around the oil pan, but can't locate it. Does anyone have a sketch or can direct me to it in the archives? Thanks!
    Don
  • Patrick T.
    • September 30, 1999
    • 1286
    Re: wooden engine support
    Here is what I made up from 4x4's and 2x6's. PT
    • Clem Z.
      • January 1, 2006
      • 9427
      why go to all that trouble when you can buy a metal one with casters so it can be rolled around for about $50. plus it can be taken apart for storage
        Don -
        If you mean the one to use when jacking up the engine without denting the oil pan, the photo is below; the base is a 2x6, and the sides are 1x6. Crude, but effective.
        • Patrick T.
          • 1286
          "why go to all that trouble when you can buy a metal one with casters so it can be rolled around for about $50. plus it can be taken apart for storage?"
          Got one of those too! PT
          • don izzo
            Clem I bought one and my engine is currently mounted in it however I need to mount and dial in the lakewood scattershield. It requires that I mount the flywheel and scattershield to do this and the stand I bought wont allow me to do that.
            Don
            • don izzo
              John thats the one Thanks! I thought I saw a print or sketch posted here about a month ago but I'll be damned if I can find it in the archives.
              Tell me, what part of the motor rests on the top of the 1x6 uprights. And the notch, is that to clear the oil dipstick?
              Don
              • Mark J.
                • March 1, 1996
                • 254
                One more sample
                I used John H's plan and some scrap lumber. The flywheel is still attached.
                  Don -
                  The pan rail (where the pan bolts are) sits on top of the side pieces, and the notch is to clear the dipstick "bump".
                  • Christopher R.
                    • March 31, 1975
                    • 1599
                    Look at:
                    www.motofeet.com
                    They make an engine stand that'll allow you to attach the bell housing and transmission.
                    Not widely available. A little expensive.
                    • Joe C.
                      • August 31, 1999
                      • 4598
                      I Used This One On The Old Tin Lizzie *NM*
                      • Brian Monticello
                        Re: I Used This One On The Old Tin Lizzie
                        saddle w/ a 4 post, jeck tray, and a $15 scissors jack
                        Brian
                        • Brian Monticello
                          forgot the pic! *NM*
                            • 43232
                            chris and Don-----
                            These are "the only way to go". I have several sets of these that I use.
                            • Terry F.
                              • September 30, 1992
                              • 2061
                              Thanks for the good laugh! Terry *NM*
