63 A frame dust shields - NCRS Discussion Boards
  • Arnold P.
    • August 31, 2005
    • 48
    who sells the most "correct" shields? are they the thick ones? thnx,pappy
  • Jim V.
    • November 1, 1991
    • 587
    Re: 63 A frame dust shields
    Nobody that I know of sells the thick material as used in the originals... Hope I am wrong.
    • Alan Drake
      Please do a search on "A Arm Seal" sometime in Nov 06.
      I never found any thick seals, Dr. Rebuild did known of porblem, however has found no source for the .100 thick seal.
      Best bet is NOS from a supplier or dare I say ebay.
      The 63-66 are different from the 67's so watch out.
      If you need pictures email me, unable to post pictures.
      • Mike M.
        • May 31, 1974
        • 8385
        try Steele or Corvette Rubber. i bought a piece of material to make a-arm shields for the 41 Willys that has a c-4 front suspension and i wanted A-arm dust shields. they supplied the material and i cut it to size. think it was thicker than the current repo shields but willy isn't here at present to mic the thickness . good luck, mike
        • Alan Drake
          Mike,
          Great idea however Steele Rubber Products does not have any sheet material and Corvette Rubber at 800-216-9412 from the web site is not a corvette number.
          So if you have time could you try to determine who your material came from. This would be the best way to get the A Arm Seal.
          • Gary B.
            • February 1, 1997
            • 7024
            • Alan Drake
              Re: Corvette Rubber contact info
              Thanks Gary,
              I did have the wrong number!
              However Corvette Rubber only has the .075" repro material not the .100" original stuff. They did give me their supplier, Paragon, but they only have the .075 also. Have traded a number of emails with Dr Rebuild on said subject reaching the same conclusion, so if anyone finds raw material at the .100" thickness PLEASE post the source. I'm sure many want to know.
              • Jim V.
                • November 1, 1991
                • 587
                Update....i just recieved the correct thickness from LIC.....GOOD news...!
                • Jim V.
                  • November 1, 1991
                  • 587
                  • Arnold P.
                    • August 31, 2005
                    • 48
                    hi,jim. is the thickness of the shields approx. .100"? not the .075 that the others are selling. thnx,pappy
                    • Arnold P.
                      • August 31, 2005
                      • 48
                      • Jim V.
                        • November 1, 1991
                        • 587
                        you bet..... .100ish..
                        yep..
                        • Jim V.
                          • November 1, 1991
                          • 587
                          yep..
                          • Arnold P.
                            • August 31, 2005
                            • 48
                            Re: you bet..... .100ish..
                            jim. thnx!! pappy
                            • Arnold P.
                              • August 31, 2005
                              • 48
                              jim. thnx!! pappy
