c1 sway bar bushings - NCRS Discussion Boards
  • Greg Pic 39571
    trying to install new sway bar bushings on a 60, having a hard time bolting bushings back together.
    Re: c1 sway bar bushings
    Greg -
    Use LONG bolts first to compress the bushings, then replace with stock length bolts.
    • Roy B.
      • February 1, 1975
      • 7044
      I found the that repro's are too narrow and the hole to small
      • Bob B.
        • March 1, 2003
        • 831
        Greg,
        If I am right that you are talking about the bushings on the ends of the sway bar links, I used a turnbuckle hooked to the sway bar to compress it and I kept the bolt in place with a piece of wood on a jack beneath it. You can do it in a jiffy that way. Send me your e-dress and I'll e you a couple of photos if you need to see what I'm talking about.
        Good luck,
        Bob
        • Dave Suesz
          The sway bar bushings I got
          from Dr Rebuild were identical to the originals, except of course they weren't all squished and hard :o)
