HEI shaft seal question - NCRS Discussion Boards
  • Scott Marzahl
    Where can I get a new upper shaft seal for an HEI distributor. This is the clear plastic washer with a felt washer attached to it that sits under the "cup" that holds the pickup coil. This one is heat damaged. I opened up a spare HEI and that seal was brittle and cracked when I removed it. My first stop was GM and their computer said this part is discontinued and I did not have any luck at Autozone across the street, go figure.
    Any suggestions or Part numbers would be appreciated.
  • Clem Z.
    • January 1, 2006
    • 9427
    try
    http://www.kendrick-auto.com/ignition.htm
      • 43240
      Re: HEI shaft seal question
      Scott------
      The plastic seal and the felt washer are actually seperate pieces; they are not an assembly. The plastic seal is GM #1950569. I show it to be still available from GM.
      The felt washer was GM #1951099. It was discontinued quite some time ago. However, it is manufactured by Standard Motor Parts and is their #DG-53. Also, it's available from NAPA under Echlin #DP-110. Strangely, the plastic seal is not available from either Standard or NAPA.
      • Scott Marzahl
        Thanks Joe and Clem, it looks like I'm all set now!
        Scott
          • 15695
          Joe - The washer is the same as used on single point distributors.
          Is the seal the same?
            • 43240
            Duke-----
            Yes, they are the same.
