54 starter relay - NCRS Discussion Boards
54 starter relay
  • Benjamin C.
    • July 31, 1994
    • 134
    54 starter relay
    Was the 886 starter relay used only in the Corvette? Was it date stamped?
  • Robert S.
    • July 31, 2004
    • 377
    Re: 54 starter relay
    B.J.
    Pg. 61 of the JG says 886 or 904 doesn't mention dating. BTY its 9 points (5 originality/4 condition)
    Bob
    Bob
    • Roy B.
      • February 1, 1975
      • 7044
      Not date stamped ,good to carry a replacement if your original burns out, this is a Chevy over drive switch which will work even tho it has a forth post you don't use,(cut it off) the # on the original one cant be seen anyway, you see them on e-bay all the time around $50.00
