Hello,
I am preparing the underside of my '72 Corvette for gel coat, which requires an 80 grit surface. I am getting discouraged with the tedium of hand sanding and have a LONG way to go.
So, I am highly tempted to try blasting it. I have read that extreme caution is necessary when blasting 'glass so as not to harm it. It appears that "poly" abrasive from the Eastwood catalog may be my gentlest option. Has anyone tried this, and is it safe if I keep the pressure low and watch things? I sure don't want to "thin" the fiberglass or burn a hole through it, yet the description for poly claims it's safe for fiberglass. (I am aware of soda blasting, but I would like to do this project myself, and I don't want to invest in a soda blaster.)
I'm assuming I should start with the gentler grit, 20/30 poly, as opposed to the available 12/16 grit, but again, I'd appreciate any advice.
And, finally, the gel coat wants an 80 grit surface to cling to, and I'm wondering if anyone knows whether either of the two available poly abrasives would yield such a surface.
Thank you,
Patricia
Thank you,
Patricia
