1971 ZR2 hood and other differences? - NCRS Discussion Boards
  • Bruce N.
    • March 23, 2008
    • 83
    I know there were only 12 or so of the ZR2 produced but I would like to know if there were any differences between the regular LS6 and the ZR2 besides brakes and suspension? I have heard they may have had a different hood and/or engine components. Thanks.
    • 15601
    Re: 1971 ZR2 hood and other differences?
    No hood or engine differences
    • Bill Stephenson
      -------I seem to remember that ZR2s had an L88 style radiator set-up which would necessitate a completely different radiator support. The hood is not changed from stock LS6 or LS5 for that matter. Engine would be unchanged from LS6, already a very formidable combination.........Bill S
      • Warren F.
        • December 1, 1987
        • 1516
        Bruce,
        ZR2 racing package consisted of F41, J50/J56, V01 mandatory options, also precluded options A31, N40, C50, C60, U69/U79 & P02.
        LS6 could have been ordered with all or none above.
        • Bruce N.
          • March 23, 2008
          • 83
          Thank you for your responses. Warren can you help me out with a translation for those option numbers - or help me find a site that translates them. Thanks again.
            • 43221
            Bruce-----
            F-41 is the HD suspension option. It consists of larger front stabilizer bar, higher rate front coil springs and a 7 leaf rear spring.
            J-56 is the HD brake option. It consists of "dual pin" front calipers, front caliper supports, caliper pistons with Pyroceram insulators on the face, and HD brake linings for all 4 calipers.
            V-01 is heavy duty cooling. It consists of the installation of the GM #3007436 aluminum radiator (and supporting pieces like radiator support, hoses, etc.). No radiator shroud was used with the 3007436 aluminum radiator.
            • Bruce N.
              • March 23, 2008
              • 83
              Thank you Joe. This information is very helpful.
