Difference between63 and 64 lower A-frame? - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    Can someone please explane the difference between a 63 and a 64 or later lower A-frame? I'm told there is an extra bracket on one or the other.Also is a 63 chevy car and a 63 Vette upper A-frame shaft the same? Thanks Stan 19259
    • 43221
    Re: Difference between63 and 64 lower A-frame?
    Stan-----
    I believe that the difference in the 1963 and 64+ lower a-arms involves the addition of a welded-on reinforcement to the 64+ pieces. This reinforcement is seen on the inner forward side of the arms.
    1963 passenger car upper a-arm shafts are not the same as 1963 Corvette. However, 63-82 Corvette upper a-arm shafts are the same as 65-70 passenger car.
    • Philip C.
      • December 1, 1984
      • 1117
      To add to Joes post 63 64 65 upper arm shafts are square at the bolt to frame bosses and 66 up are round.Phil 8063
      • Stan E.
        • April 30, 1991
        • 383
        Thanks guys, it is appreciated!!!! stan19259
