C2 Oil Pan Removal - NCRS Discussion Boards
C2 Oil Pan Removal
  • Ralph E.
    • February 1, 2002
    • 905
    C2 Oil Pan Removal
    Need to remove the oil pan on my 1967 sb 327/300 to replace the oil pump.
    What are the best gaskets to use?
    Any sugestions or pit falls that I should be aware of?
    Ralph #37280
    • 43221
    Re: C2 Oil Pan Removal
    Ralph-----
    The best gasket to use is a one piece-type gasket such as Fel-Pro OS34509T (that number assumes that you have an original GM #3820000 oil pan).
    Pan R&R is very straightforward. However, you'll need to lower the steering relay rod to gain enough clearance to remove and install the pan.
    • Joe R.
      • March 1, 2002
      • 1356
      I have read here on the Tech Board that there is a preferred position for the crankshaft that gets most of the counterweights out of the way, which helps with oil pan removal. Of course, I can't remember what that position is, but maybe someone can chime in, or maybe you can find it in the archives.
      • Clem Z.
        • January 1, 2006
        • 9427
        put the TDC mark at the 6:00 position *NM*
        • Ralph E.
          • February 1, 2002
          • 905
          Joe,
          Went to NAPA to get Fel-Pro Oil Pan Gasket OS34509T as suggested. They told me it is NOT a one piece gasket. Any other suggestions?
          Ralph #37280
          • Clem Z.
            • January 1, 2006
            • 9427
            one piece pan gasket fel pro
            SBC 1957-1974 #1885, 1975-79 #1880
            • Ralph E.
              • February 1, 2002
              • 905
              Re: one piece pan gasket fel pro
              Thanks,will call tomorrow.
              What is the difference between the FPP-1885 and the Fel-OS34509T
                • 43221
                Ralph-----
                Don't believe what some parts counter people tell you. Did they SHOW you that it was not a one piece gasket or did they just TELL you that it was not a 1 piece gasket? If they order one, then they'll see for themselves that it's a 1 piece gasket. Won't they be embarrassed?
                Fel Pro OS34509-T is definitely a 1 piece gasket for 57-74 Chevrolet small blocks (with original pans) unless Fel-Pro changed the number from a 1 piece gasket to a multi-piece gasket set. I consider that chance about as great as the chance that the people in hell will get ice water.
                • Ralph E.
                  • February 1, 2002
                  • 905
                  Joe,
                  I agree with you. Some of these parts guys need a little "guidance".
                  I suggested to them to order the OS34509T and we could check it out together.
                  But I will also have them pick up a FEL-1885 if necessary. Thanks Clem!
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    joes # is referred to a OEM performance where 1885 is referred to as high performance. whats the difference i have not a clue as i have only used the 4 digit numbered ones
                    • Wayne P.
                      • August 31, 1975
                      • 1025
                      I ordered one last week based on a post here. It was 4 piece. At least that's what the parts guy said when it came in. I didn't see it.
                        • 43221
                        Wayne-----
                        Are you saying that the Fel Pro OS34509T turned out to be a 4 piece gasket? Attached is a photo of a Fel-Pro OS34509T gasket that I have here. The box was never even previously opened; I just opened it here for the first time to take the pictures.
                        So, unless Fel-Pro has completely changed the gasket that they market as an OS34509T, which seems extremely unlikely to me as it would cause mass confusion, then the OS34509T is a 1 piece gasket.
                          • 43221
                          Another Photo
                          Here's a photo of the box and the complete gasket
                            • 43221
                            Yet Another Photo
                            Here's a photo of the major label on the box.
                            • Stephen B.
                              • December 1, 1984
                              • 98
                              Re: Yet Another Photo
                              I believe it is listed as a muti part kit but the other parts are new bolts because the gasket is thicker I have used quite a few of these kits and like the results but the draw back is the bright blue color small price to avoid oil leaks steve
