I was recently involved in a discussion over the factory usage of the '7115
crankshaft of L-88 & ZL-1 fame. This basic topic had been discussed here
a few times over the years and I was wondering if any members here can
expand on this for me.
I know the '6223 crankshaft was used in L/78 & L/34 production. Obviously, the
L/78 application used cross-drilling & tuff-triding. I learned here that the
'6223 crankshaft was also used in the L/68, ( L/36 also I believe ), and the
L/71 & L/72. I know that the L/71 & L/72 got the cross-drilled & tuff-trided
version of this crank as well.
I had always heard the the 427 crank had heavier counter-weights to offset
the increase in piston size. I believe Colvin states this in his books. Based
on the number of members here with 427's with '6223 cranks, I now wonder if the
only applications for the '7115 crankshaft were the L-88 & ZL-1. I expect this
was because of the major power differential as well as the hugh domes on these
two particular pistons ( probably the same piston anyway ).
Can anyone tell me if there were any other crankshafts used in the '69 model
year for passenger car 427 ( Corvette ) applications?
Steve
Steve
