I have been struggling with this overheating problem for 4 months now. I have a fresh rebuilt numbers matching block. Heads are from a 77 305 Camaro. New aluminum radiator. Rebuilt water pump. Rebuilt wcfb carb. I have the engine timed to factory specs. Engine runs great for ten minutes and then temp climbs above 240 at water neck outlet. I have an infrared gun. If I let it run it will boil over and blow lower hose off. This is with 50/50 mix of water and antifreeze. The body is off the frame.
Here's what I have tried: Pulled heads and checked all passages for obstructions. Replaced head gaskets. I tried a different water pump. Flushed engine twice and replaced fluids.
I'm thinking theres something blocking a passageway and is not letting water where it should be.
Any further ideas before I break the engine down all the way?
