'70 LS-5 Tach - NCRS Discussion Boards
'70 LS-5 Tach
  • D S.
    • March 1, 2005
    • 1551
    '70 LS-5 Tach
    I searched the archives on this but found no posts so here's the question: Where does the yellow arc and red arc begin on a '70 LS-5 tachometer with A/C and automatic?
    Scott
    • 43222
    Re: '70 LS-5 Tach
    Scott-----
    I believe that the yellow arc starts at about 5800 RPM and the red arc starts at 6000 RPM and extends through the remainder of the RPM range on the tach.
    • D S.
      • March 1, 2005
      • 1551
      Re: '70 LS-5 Tach
      Thanks, Joe! I saw what was described as a '69 up big block Corvette tach on eBay and the yellow arc started around 6200 and the red ended at 7000. Kinda jump started me to thinking I had the wrong tach. You can imagine how that had a mental domino effect.
        • 43222
        Re: '70 LS-5 Tach
        Scott----
        The tach face that you describe was used for L-71 engines.
        • Mark #28455
          That's 350/350
          LS-5 redline is 5600 RPM.
          Mark
          • D S.
            • March 1, 2005
            • 1551
            Re: That's 350/350
            Thanks. I saw that, too, after, the posts and after I uncovered my Corvette today. I saw that my yellow started at 5300 and the red ended at 7000 on mine. So I went through a bunch of photos of '70 LS-5s with automatic and A/C on eBay and so did those.
