More 68 uniquness? - NCRS Discussion Boards
More 68 uniquness?
  • Steve Wallach
    More 68 uniquness?
    I'm doing an extentisve restoration of my 68 L71 and have done an intenstive search and comparison to other years looking for some of the smaller items.
    Here's a few items I've noted to 68s.
    1. The firewall upper cowel seems to be unique to 68s (possibly early 69 also, but haven't confirmet that)
    2. The T-Top strap hardware is unique to 68s. I haven't been able to find the small spacers that go under the T Top strap hanger brackets except at a Corvette Grave Yard. I haven't been able to find the Chrome Machine Screws that hold the hangers to the screw plates except used either.
    3. The Headlight doors are different sizes and slightly different molding.
    4. The door handles are different.
    5. The plastic grills are different.
    6. I have done extensive comparison of cars that were built around the same time frame as mine. The rivet locations are different in many instances, so the templates used either had a lot of lattitude, or they just suggested locations?
    7. The Door pin for the interior light, seems to be in different locations on the pillar of the Bird Cage on various 68s. This also means that the door pillar fiberglass pieces were molded differently, because the holes in the fiberglass is also in different locations on these pieces?
    I'm sure the differences are too numerous to list, but it is interesting how different 68s built days apart can be!
    Steve
  • Gene M.
    • April 1, 1985
    • 4232
    Re: early 68 uniques
    position of mirror on door, blank space on console, 67 style antenna, pilot build stampings on inside door panels and unique pull area, powder blue text on washer knob at center console, radio knobs, position of pulls for overrides under dash, can and bellows for wiper door, acorn nuts for top latches, no caps on hard top corners, center stowage tray cover, battery cap vents, no insulation under floor except tunnel, no chin spoiler, rough cut outs for air to radiator, silver trim on grills, tire lock like mid year, center ear on front bumper, side window glass has metal structure bottom, seat release is low position with special seat backs, shifter console has two shades of black, no dimmer switch pad, unique seat belt retractors that seldom work............sorry there are more but the mind is going blank
    • Jim S.
      • September 30, 2003
      • 77
      69 435hp finally rescued
      I may be suffering from CRS but I vaugely remember the astro ventilation on the rear deck behind the back glass on my 68 being just a rubber flap while on all my 69's and later it was vacuum operated, but it has been over 30 years since I had a 68.
      • Terry F.
        • September 30, 1992
        • 2061
        Re: 69 435hp finally rescued
        Your recollection is correct. Terry
