C2: Need 2nd Opinion... Clem - NCRS Discussion Boards
  • Michael H.
    • January 29, 2008
    • 7477
    A friend is rebuilding the FI 327 in his Corvette for normal street driving. He found a new set of older 11.0 Forged pistons that have the typical thin 1/16" 1/16" 1/8" ring grooves used on racing pistons. Do you see any problem using these on the street? Car may see 10,000 miles or more. I see no reason why they wouldn't work well but just wanted another opinion. Thanks.
  • Clem Z.
    • January 1, 2006
    • 9427
    new car engines use thin rings with no problem
    just make sure the oil ring expander is not a low tension one
    • Michael H.
      • January 29, 2008
      • 7477
      Re: new car engines use thin rings with no problem
      Ok, thanks Clem. Just wanted to make sure. Never hurts to have a 2nd opinion, especially for parts that are way down inside the motor.
      • Clem Z.
        • January 1, 2006
        • 9427
        it will make more HP also because of less drag *NM*
