67 Ignition switch connections. - NCRS Discussion Boards
  • Richard S.
    • November 1, 1994
    • 809
    The connector on the back of my 67 ignition switch does not have a wire in the slot marked "GRD"...which to me means "Ground". The car starts and runs fine. Should that slot in the connector have a wire in it or not?? Thanks.
    PS: There is also a brown wire with a black connector which is not connected to anything, hanging near the ignition switch. Should this brown wire be connected somewhere?? The car has no radio if that means anything.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 67 Ignition switch connections.
    Your wiring diagram shows no connection on the ground lug of the switch.
    Also per your AIM... no radio no connection on the brown wire. With a radio there would be a capacitor connected here
    • Richard S.
      • November 1, 1994
      • 809
      Thanks....much appreciated.. *NM*
        Re: Thanks....much appreciated..
        Rick -
        If you don't have the radio noise suppression capacitor that mounts adjacent to the ignition switch, be sure to tape that brown wire out of the way - it's "hot" any time the key is "on", and you don't want the connector to touch anything that's grounded.
        • Richard S.
          • November 1, 1994
          • 809
          John,
          Thanks for that advice. I was browsing the other forum and came across your warning regarding that wire this morning. I took care of that brown wire this afternoon....your thoughtfulness is very much appreciated.
